Re: Abnormal wear of rear brake hanger. What have I done? Help!
Ok here goes, I do have a drift hammer but the bearings are seated correctly and unlike most Yamaha factory parts are bathed in grease.
I also thought that the bearing may have been seated wrong but on the left side there is a bloody great cir-clip in the way and on the right side it would seem that I have the required protrusion. There is no spec to drift it to.
The red stuff previously seen on the caliper is copper grease.
Fred I even cleaned the thing prior to commencing works lol, even soaked the chain in Kerosene as I had two stiff links.
Obvious wear on hanger
Rear wheel spindle & spacers
Left side
Left spacer out
Left spacer in
Right spacer out
Right spacer in (Thanks to my daughter Caitlin [6] for supplying the third hand)
Chain adjusters out, apparently notorious for being out of line. These two are pretty close in terms of thread and length adjustment. Having said that they do not alter the plain of the hanger, regardless of adjustment.
No torque on spindle with initial alignment
Torqued up to spec @ 120Nm
torque wrench setting, it didn't come with instructions so I assumed you dial in the closest setting then fine tune with added units so mine is at 112nm and I added 8 to make 120. Is this correct?
Swing arm hanger guide once torqued up. There is about 2.5mm exposed as the hanger does not sit flush. Is this to spec guys? Can you have a look at your bike and let me know?
I may have been a bit misleading when I said that undoing the spindle nut resolved the problem. The rub was still there but I was able to physically pull the hanger to wards the left-hand side so the rub was reduced.
When I did the swing arm pivot service the swing arm dropped in a horizontal plain. I couldn't figure how to realign it. I did use a considerable amount of muscle trying to get the B@stard into place until I realized I needed to lift it up horizontally to align it. Could I have twisted the swing arm?
I am still perplexed and frankly fed up with this issue. Other than that the bike is riding like a dream.
Neil
