Clutch switch... what does it do?
maverick1970
Super Member
Jackson, Georgia, USA
I broke the little plastic piece for the switch that's on the clutch lever. See picture #7 / part #3YX-82917-01-00. Does anyone know what the switch does?
Ronayers.com Fiche Desktop Motorcycle Yamaha 2008 FZ6 HANDLE SWITCH LEVER
I've been able to super glue the little plastic button back onto the switch, but if worse comes to worse, I'll buy another one.
It won't let you start the bike in gear unless the clutch is pulled in.
With the switch broken, you'll have to put the bike in neutral to start it. No biggie.
Fred
I'd say spend the $0 and just cut the switch out and wire the circuit to be permanently closed. Just make sure you remember to pull the clutch in when you go to start the bike (if it's in gear). I did this when I swapped out my clutch lever assembly and haven't had any issues since.
hello i need to bypass mine. what color wires are they from the connectors????
You have all of the schematics, wiring diagrams, PDF files we have. You had that in your original posts in another thread. . . . . It's all there you just have to look!!!!! - I'm going for a Ride!
