Grouse
OK thanks in advance for any help with this as it's got me beat.
My bike had not been used for 2 weeks due to flat tyre and work commitments, so today I decided to have a ride.
The first thing I noticed was that the cold idle was just over 2k which is a little fast. After it has warmed up a bit idle dropped to about 1200, it only returned to the normal after I blipped the throttle.
As this was the first ride since replacing the front wheel I pumped front brake a few times an push on the handle bars I noticed the engine revs dropped every time the front end dipped.
I decided to try a little ride get it all up to temp and hopped it would go away, it didn't. The bike will stall if I break with the clutch pulled in or if I just rock the bike on the front break 4 or 5 times. It is also lumpy if I try to hold it under 4k in low gears but is not as noticeable in higher gears.
Thanks for looking and any help.
Grouse
Grouse
