Ooh, found out that CO1 and CO2 does not denote cylinders 1&4 and 2&3 respectively. It denotes the air/fuel mixture at certain throttle openings and RPM's. [Did not see the conclusive evidence in this thread, hope I am not duplicating a post]
Anyway, I read it in a 2003/4 R6 SS kit manual by YEC.
The R6 has CO1-4, we only have CO1-2. So I predict that the lower CO1 setting is for a leaner mixture at lower RPM's.
So it is not necessarily for keeping cylinder 2&3 cooler...
However, I may attest that the CO adjust definitely smooths out things and may even unlock a bit of the H&P's (Horses and Powers).
Mainly because even though our bikes are based off the r6 engine it has a completely different ecu and tuned for everyday drivability vs racing, someone correct me if I'm wrong because I don't have a shop manual in front of me but I'm 90% sure our shop manual says that c1 is for cyl 1&4 and c2 is for 2&3. But yes the end product is a altered air to fuel ratio, because by going up or down on your co it increase the fuel into those cylinders or decreases it. Is a good idea to write down your stock settings to remember. Mine were c1 -27 c2 -13 and I moved both of them up evenly and I think I have moved them up both 17 points, unhooking the battery everytime I made an adjustment. I choose going up 17 points but the good old fashioned butt dyno in 6th gear wot, and how it reacted and how long it took to climb to top speed, I originally had moved it up +30 which was WAY too rich and I keep leaning it out until the bike felt right.
I'll also add that the #1 reason why our bikes are different from the r6's and even have a co adjust on them is for it to meet emission regulations, when the bikes first came over here they were not emission friendly, so instead of sending the bikes back Yamaha needed a way for the dealers to fix the issue, so they added a simpler co adjustment, the dealers would stick a sniffer in the tailpipe and adjust the co levels until they were where they needed to be, that is also why every bike has different co values
^^ Well said Chev!
Ya, our bikes have group fire injection (a single wire fires two injectors) and and waste spark ignition (a single coil fires two plugs). There is NO Comparing the R6 to our bike in regards to the ECM, what it does and how it does it.
Just trying to clear the air as incorrect information has been thrown in here.
One area I do have heartache with is this:
Assuming the Yamaha tuning gods needed to "balance" the inner and outer cylinders they have no WAY of reading the independent cylinder hydrocarbons. 4 into 1 with a single outlet does not allow fine tuning at this level.
So - although I agree 100% its fueling banks 1 & 4 and 2 & 3 per C1/C2 it now becomes more complex unless you do some something like the following:
Cut the spark and measure cylinder performance (power, vacuum drop, efficiency)
Measure exhaust gas temperature (IR, or direct), neither accurate for emissions purposes IMO.
Use the adjust function in combination with Throttle body vacuum readings.
So, without taking the exhaust off, how does one measure which cylinder is doing what? Although this might explain the huge variance in some bikes being -27/+5 and others being 0/0 and the other spectrum of +10/+25.
It may also explain why some don't feel any difference as their bike is already optimal (richer than necessary) i.e running > +15 etc.
Although not accurate, a tech could run each pair up and down repeatedly through a range of "-" and "+" and average out its effects with an o2 or hydrocarbon sniffer. Repeat on the other 2 cylinders. Pick the sweat spot where both pairs provided some calculated ideal value and BAM. There is your number based upon what was DONE vs what its doing. Because they don't know which pair is responsible for what until its value is moved then monitor the combined pair for total emissions. One effects the other as it changes the fill volume of the cylinders when the idle speed changes.
For What Little Its Worth (FWLIW); US, 08, settings were 0/0. With 2Bro, filter box mod, 89 octane fuel, and 150ft off the deck (Sea level +150), my bike is much smoother having more fuel added. 25/25. It rev's quicker, pulls better, pops more on decel, and it may have made the chop worse regarding off throttle fueling. I need to ride it more to determine that.
Because its running unadulterated fuel (meth free), the plug colors now look chocolate brown as opposed to stark white. Old school tuning eye says its getting more fuel due to plug color.
JJD952 - tuning
