This thread has captured my interest. On a side note, does advancing the timing have any adverse effect on engine longevity?
My grandpa always said the brightest bulb burns out the fastest. Just wondering if that applies in this situation.
Spark advance is supposed to be set so that the flame front starts pushing the piston down, right after it reaches Top Dead Center.... If the spark is delayed, that means you lose power because the piston is not being pushed down through it's entire stroke. Less power, in the power stroke.
I'd have to wonder what the programming on this thing looks like, from Yamaha. Every motor has to have variation in the spark advance, to compensate for higher RPM. The flame front advances at the same speed, regardless of RPM.... in order to keep the expanding gasses pushing down on the piston through the whole firing stroke, the spark needs to be advanced in time to account for the higher speed of the piston's rise.
The relation between advance and crankshaft speed should be linear. If you ideally have 5° advance at idle, the advance has to get 'longer' with RPM. Whatever the change from 5° is at 3K (from 5 to 7°?), it's going to be 2X that at 6K, 3X at 9K and 4X at 12K.
My concern with this is whether Yamaha accomplishes the 'excessive' retardation at low RPM by programming the ECU, rather than by mechanically delaying the timing.
If it's programmed, the changes you 'see' at low RPM aren't going to be the same at high RPM.
I've seen a number of Dyno plots on this board, from bikes made for pretty much every market in the world.... I don't see any of them that make more power down low compared to other markets. I'd expect at least one world market to be selling the 'full zoot' motor.... and I don't know of one.
It might be worth checking to see what p/n there is on the ignition advance plate on a YZFR6 motor of the correct vintage, to see if they 'dumbed it down' on the FZ6...
Sorry, I realized I didn't answer your question directly.
Yes, advancing timing too much can be a Bad Thing. If the spark occurs early enough the expanding gasses of the fuel air charge hit the piston BEFORE top dead center. Pre-Ignition. This leads to the con rod bearings hitting the crank shaft, which is where that death rattle sound comes from on cars that are dieseling after the ignition is shut off. It can lead to melted pistons as well; I'd suspect damage to the rod bearings would happen first.
There ain't no such thing as a free lunch -- TANSTAFL
