fZling
Re: Knock knock \\ Look inside before you go further!
The (slight) knock started about 100 miles, after I purchasing the bike. Perhaps I even bought it with the knock and just didn't ride it hard enough to hear anything. The slight knock was between about 4.5-5.5rpm, only during acceleration.
Once the heavy knock hit it happened at idle, didn't bother to try and accelerate after hearing it :jawdrop:
The oil filter was clean, but there were a slight silver goo that came out under connecting rod #3.
The gas was brand new, only used premium as well.
I changed the oil almost right after I bought the bike and according to the sheet he gave me, the oil was changed 600miles prior to me purchasing it.
I'm late in the game but have a few suggestions:
When exactly did the noise start?
Idle:
Under load:
While decelerating:
Coasting - all the time:
With a good load of bad gas and/or a real lean condition from a bad fuel pump, injector issues, plugged fuel pick up, anything making a super lean condition these will make a horrible piston knock which would be prominent during start up, acceleration, under load.
Again - cutting the oil filter open now, will show you the damage. If the filter is clean, tell us about the last load of gas! Poor some out and run in it your lawn mower if you have too. how old is it? How did it run the last time you road it? Was ran out of oil? What are your OC intervals?
If the Oil filter is full of copper and lead looking material, you lost a bearing. If not, I'd inspect the fuel filter and gas.
Tell us everything you know!
