A little off topic but thought I would share this little contradiction I found in the manual (or maybe that's my interpretation of the manual). :spank:
Page 341 says the following:
Lean angle sensor Remove the lean angle sensor and incline it more than 65 degrees.
• Upright 0.4 – 1.4v
• Overturned 3.8 – 4.2v
VS.
Then on Page 376
CHECKING THE LEAN ANGLE SENSOR
1. Remove:
• Lean angle sensor (from the bracket.)
2. Check:
• Lean angle sensor output voltage
Out of specification → Replace.
a. Connect the lean angle sensor coupler to the wire harness.
b. Connect the pocket tester (DC 20 V) to the lean angle sensor coupler as shown.
c. When turn the lean angle sensor to 65°.
d. Measure the lean angle sensor out put voltage.
Lean angle sensor output voltage 65°: 1.0–4.0 V
Note: "a" implies the harness is the DMM meter connection I think.
Reseting the sensor is to turn the key to the off position and then back to the on position once tripped.
TAGS:
Diagnostic code, 08, #08, lean angle sensor, lean angle, fault code 41, fault code no 41, fault code 30, fault code no 30
VS.
Then on Page 376
1. Remove:
2. Check:
TAGS:
