sixsix
Finally got my bike converted over to naked. I used the FZ16 headlight from dev_usc Going thru him was painless and everything arrived in perfect shape. I did run into some problems and I was wondering if anyone else with this set up ran into. In order to get the head light stay straight, I had to cut a portion of it out where it meets up with the lock cylinder. Good thing I had a dremel, there was really no other way that I could see to modify it to get it to work with out cutting it. Doing this pushed the whole stay back, so when it came time to mount the speedo I had some problems. Then it seems like the stay was a good 3 inches wider at the mounting points for the headlight. I didn't bend it tho, just left it like that and didn't tighten up the bolts securing the headlight to the stay all the way. Then the clips with the bolt attached to it that holds the painted pieces to the head light are complete junk. The bolts wouldn't thread into them cause the threads on the inside of the nuts were all screwed up. I ended up accidentally breaking a piece off the head light due to this. I had some extra nuts laying around that fit so I just used them. And now for some reason my blinkers are going crazy. They work fine when you first turn them on, but like 5 seconds later they start blinking really fast. I also never could get the running light under the headlight to work either. But I'm done for now. I still need to clean up all the wiring...right now the wiring harness is just shoved behind the head light. I read somewhere that some one pulled the harness back into the frame so I'm gonna try that one day. I still need to mount the mirrors but Im to tired to do anymore today. Enough of my rambling, here are the pics
These are the bolts that gave me problems
and the video of my blinkers going crazy
[ame=http://www.youtube.com/watch?v=SlZb18wu2kk]YouTube - Fz6 blinker problem[/ame]
