Stripped hex bolt trying to install Rizoma handlebars...
maxpower3
USA
Alright, here's the deal: I'm trying to install some Rizoma billet grips + bar ends that I got recently. I went to the bar ends of my 08 FZ6 with a hex wrench (allen wrench) to try and remove the stock bar ends. Only problem is that I immediately stripped the hex bolt holding the stock bar end on.
What are my options now? I've heard of "easy off," but I was hoping there was a simpler solution I'm overlooking that doesn't involve me shelling out for drill bits.
Thanks in advance guys.
WOW how did that happen?? I know they where really tuff but did you make sure it was all the way in the head of the bolt and correct size. I think its metric... Easy outs do work but if it was that tuff i'm not sure if they will. If they dont work try a reverse drill bit. If that don't work buy new bars.
Take a shop towel and wrap it around the head of the stock bar end. Now take some adjustable pliers, grab the bar end (over the shop towel, obviously) and turn. That's how I've always taken mine off. And since you're replacing the stock ends with aftermarket ones anyway, you can forget the towel if you like...that's just to keep from scarring up the bar end anyway.
You'll really have to muscle them...those things are on there TIGHT from the dealer!
Wow guys. I think the poster above was right -- I was trying to loosen the bar ends using the "inner" bolt, not the larger 8 mm outer one. I feel dumb. Alright, I'll go try that and see what happens. Thanks all.
Dude, be very patient with this stuff! stripped bolts are the worst thing so get it right the first time. Don't ask how I know what a Heli Coil is :D and why I have a can of Liquid Wrench in the garage.
Dennis
so they larger part is 8MM and it is the one to be turned? i was gonna do it today and was having a hard time and was confused if i was using the right thing.
A decent allen key is good if you have one. Then you can provide more leverage by putting a pipe over it. Worked great for me. I prefer it to my socket for breaking things lose. Less expensive if it snaps! :D
