Ok, been through this two times with new cars.
The first was an Impala many years ago. The filter was so tight it would not budge no matter what I tried. As a last resort, I drove a screw drive through the filter to turn it off.
"Big mistake". The filter tore in half and I had a situation on my hands. Took me a day and one half to get it off, if I remember correctly.
Next time I had this problem it was a new Toyota truck. Because of my experience with the Impala, I decided to take it to the Toyota dealership and let them get it off.
I walked into the garage area because I wanted to see how they would get it off.
The young tech. used a long screwdriver and drove the tip of the screwdriver between the seal of the filter and the smooth machined base on the engine.
Once the seal was broken, the filter came right off.
He said this was normal procedure for removing stuck oil filters.
I know that machined surfaces must be dealt with carefully and not gouged or scratched but, if this procedure is done carefully, it will not scratch the oil seal machined surface on the engine.
Use this procedure as a last resort and carefully align the tip angle of the screwdriver parallel with seal surface on the engine.
If you are in a fix, this will work.
good luck, ice
