Fork Oil Stock Weight?
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
I am undersprung, and I would like to replace my stock fork oil with a heavier weight. I was wondering what the stock fork oil comes with.
And how many quarts will it take to replace the oil?
I'm going to try to just replace it with heavier weight oil rather than getting new springs. I weigh about 160 lbs with gear and I don't think new springs will make that much of a difference.
I used 15 weight and love it!
also .467 Quarts per fork :)[/QUOTE]
Is that with stock springs? In what way does it make a difference?
Just asking cos i'd like to improve the ride without great cost. thanks
Just asking cos i'd like to improve the ride without great cost. thanks[/QUOTE]
I re-sprung, but just thicker oil will make the forks a bit more predictable and less reactive to every little bump in the road. Less jittery if you will...
Hey Vegas, :rtfm: and do a search....this has been covered many times! (just messing with you)
:D :D :D
Are you going to do the work yourself?
I hit the search and it came up with 21 pages of threads. I found some with related subjects but not specifically what I was looking for. I had no idea that the stock fork oil only came in 5 weight.
Will go with 15 weight and see how it does.
As far as doing the work myself, I'm actually going to get my steering head bearing replaced by a local mechanic, and I'm going to have the fork oil replaced at the same time. Origianlly I had planned to get new springs, but opted to try different weight of oil first.
Hey Vegas have you changed your fork oil to 15w? I'm thinking of doing the same. The stock springs rate is close to what the racetech calculator recommends for my weight, but I'd like something a little harder on the front. I wonder if changing the fork oil would do it.
Sad to say no. But will do it very soon. Just trying to squeeze my bike into the shop that 's going to replace my steering head bearing too.
Working out the logistics, since my bike is my only ride, and this particular shop is 20 miles away from work, it will be tough to get my bike fixed with conflicting schedules.
Seems like the perfect opportunity to rent a car and see how the other 98% lives!:D
Just kidding , I'm sure it's the case with most states, you have to have a drivers license in order for you to receive your M endorsement.
However, because I only have motorcycle insurance, my insurance will not cover any rental vehicles, so I would have to purchase the insurance from the rental agency, which can exceed the actual cost of the daily rental for the car. In any event, if I ever do, I'll be sure to take advantage of the insurance and drive the car like a rental should be driven.
There you go: Las Vegas Scooter and Moped Rentals
I'm sure you've always wanted to try one of those bad boys :)
