Now you need to put all your bits back together.
Don't forget to reconnect the male connector to the ECU housing.
Reconnect the 2 wires under the fuel tank (Green connector at the bottom)
When releasing the tank back down from the bungees be careful that your fuel pipes don't snag on anything.. Also make sure the fuel vent pipe on the right goes back through the little loop at the bottom of the bike. It just hangs there.
Next replace the tank bolts. Thats the tank back secure again.
Now all that is left is a quick positioning of the Digi Gear Indicator.
I chose the position in the picture but I suppose its dealers choice
I drilled about a 12mm hole in the dash to get the connector through... It then just clips into the other connector that runs the wire to the ECU wires. All nicely tucked away out of sight behind the dash housing.
I superglued one half of the velcro type stickers that come with the indicator to the dash for extra strength. The sticker alone wasn't that secure.
SO... with it all in place the final job is an easy programme.
PROGRAMMING THE DIGI GEAR
ENSURE BIKE IS ON CENTRE STAND OR A PADDOCK STAND !!
a)with the engine running and the bike in neutral the Indicator will display 0 (this is the sign for neutral that you can change to n if you wish)
b)Insert and hold the programming key in the back of the unit until an L is displayed. (aprox 10 secs)
c)with the L displayed press the key 6 times ... once for each gear.
d)Remove the key and wait for the Neutral indicator to appear. (leave engine running)
e)select the first gear,let the clutch out and run the engine between 2-4000 rpm until the 1 flashes. The display will then change to 3 bars and then to a number 2.
NOW SELECT NEUTRAL
f)Now select 2nd gear and run til the 2 flashes then changes to 3 bars then number 3 ... Now select 3rd gear and do the same for 4,5 and 6.
You can now select Neutral and turn the ignition off.
And thats it ... easy peasy lemon squeezy !
JOB DONE
Hope you liked and thanks for lookin.
