Oye Desi, that makes 4 of us on the forum including lonesoldier and Desi_FZ6. You could get the service done with the help of some of our local forum members there. Doesn't need a lot to change the oil.
1. Get a nice 100 piece toolkit from costco
2. Get a oil filter wrench from Wally World, if possible the clamp type not the plastic socket type.
3. Set the bike on side stand and put an aluminum foil beneath the filter and drain bolt and set a oil pan below.
4. Remove the drain bolt slowly as the oil will gush out
5. Let the oil completely drain and then remove the filter
6. Repeat the process in reverse and fill the oil.
BTW, get Shell Rotella T Synthetic or Mobil 1 synthetic and a Purolator Pure One PL14610 oil filter (from Advance auto parts). Refer to this forum or this site
Motorcycle Info and Accessories for all possible questions.
I have statefarm which is like $450/yr for 100 comp and 250 coll.
