Engine guard - PICS!!!
Rather than start a new thread in 'mods' I'll post this here (for now anyway).
Here are a few pics of the SW-Motech engine guards and footpegs available via Twisted Throttle.
First, the left side. The instructions supplied are ok for this side. The front attaches to where you'd put a frame slider.
Here's a close-up of the back part of the left-side guard. To attach the back part, you remove a small bolt that goes right through the frame (it's attached to a long rod and the nut is on the other side of the bike). Yamaha has this one on with red loctite or something, so it took quite a yank to break it toose. In this photo you can see an ANSWER that has been the source of MUCH speculation....does it intefere with the oil filter. The answer is NO....sort of. The black filter you can see in the pic below is a longer-than-stock SuperTech ST7313 filter (3.25" as I recall). The guard fits over it, but you can see that there isn't much clearance. I'll be able to get a strap wrench in there, but I'm not sure I'll be able to get the filter off without removing the left side guard. If I used a normal-length filter it would be NO PROBLEM (and I will switch back to an ST6607 on my next oil change).
Here is the right side. No one ever seems to photograph this for some reason. There are also NO instructions for attaching the right guard, which is too bad, since it mounts to a DIFFERENT BOLT than the one on the left side. Make sure you have your centerstand UP when you try to mount this side (you won't be able to get the proper bolt off if it's down anyway). The small nut above and to the right of the attachment point is the point where the left guard is held on the opposite side of the bike.
I forgot to take a pic of the front of the crash/engine guards, but basically the two ends slide into a clamp that screws down to hold them together in front of the oil cooler. As you attach the guards to the middle clamp, do NOT tighten down the side bolts UNTIL you fit the front pieces together first. Otherwise you'll be bending the guard to make it fit. The instructions for fitting the front piece of the guard are ok.
Pic from the front showing the highway pegs sticking out. These were pretty easy to install. I STRONGLY suggest inserting a small piece of rubber (buy an inner tube at Walmart if necessary) to get everything snug. The pegs are very adjustable, although the black paint comes off pretty easily. It also takes a while to get them even close to level.
Here's another pic from the front. Try not to notice the messy garage!! In this pic you can see that one peg is folded up. You can also spot my new handguards as well.
****pit shot showing lots of goodies (handguards, heated grips, Calsci windshield, barbacks+risers).
Finally, a shot from the back showing my IBA "membership card":thumbup:
Having these footpegs will help on 500+ mile rides. Cramped legs has been my major issue. I think I'm getting closer to converting this things into a transcontinental tourer.....Next up will be side cases and a GPS.
