Installed Puig sliders
Cloned
Tiger Trainer
Flagstaff, AZ
Just finished installing my Puig sliders. All in all, took me about two hours- an hour of looking for my torque wrench (found it), 50 minutes of going out and buying the proper bits and adaptors, and 10 minutes of installing the actual sliders.
They sent me two different length bolts, and later emailed me confirming that that was supposed to be like that. It all worked out in the end, the longer bolt ended up going on the left side, even though the sliders themselves were the same length:confused: Whatever, they look good, and I had no problem installing them. They are longer than I expected, though.
Thanks for sharing the pictures. When I was frame slider hunting, I couldn't find an FZ6 picture with the Puig sliders on. Where did you get them by the way?
I got them from indysuperbikes.com. KneeDraggers had them in stock (which is pretty rare) but indysuperbikes had them for $76 shipped, more than $20 less than KneeDraggers.
And after looking at the pictures I realize I REALLY need to clean my garage.
They look great! I wish the Shogun's were that long!
FWIW, a clean garage is a sign that the owner does NOTHING in it. ;)
The pic's look great!! You said you had to get bits??? Did you have to drill out the frame holes or did the original bolts fit??? Let me know, I would like a set and if you don't mind where did you get them and how much did they cost??
Todd
Todd
The bits were to screw it in. I didn't have any 8mm hex bits that fit my torque wrench. The new bolts screwed right in to where the old bolts were. Nothing drilled.
Have the same ones. As they are long they saved all the fairings the other day when it fell on it's side. Not a single scar....Now about the phallus part....I don't really care, made me laugh though :D
