Wolo Wolf Whistle
S107
Long Beach CA
Ive Been Putting This Off For Months. Todays The Day I Install It Or Throw It In The Trash. I Figure With Some Light Modification, I Can Bolt The Car Alarm Sized Speaker In Under The Front Fairing. The Directions Require A 3 Amp Fuse, Could I Just Solder The Positive Wire Into The Courtesy Lights/Front Turn Signal Wire? The Switch Will Be Visible And I Dont Want People Setting It Off n Playing With It At Work. This Is Why I Dont Want To Run It Straight To The Battery.
Should It Work If I Solder The Wire With The Front Signal? If I Short It Out How Hard Will It Be To Fix? Is It As Simple As Just Removing The Speaker Wire And Replacing A Fuse?
Thanks Guys.
The Board Doesn't Like Shouting, So It Won't Let You Type In All Caps. If You Try To Type In All Caps, It Will Only Cap The First Letter Of Each Word.
REALLY? I NEVER KNEW THAT... IT WOULD JUST MAKE ME WANT TO... :stupidpc:
EDIT: HOW COME I CAN TYPE IN ALL CAPS?
CAUSE IM THE MADMAN?
