Mancolt
First things first: I am knee deep in the middle of my Bi-Xenon installation. My lack of electrical knowledge has really made this a much more difficult and long process than I had hoped. I assumed that a complete kit would come with instructions that would make the installation much more user friendly...I was wrong. The instructions for my particular kit (sportbikelites) leave A LOT to be desired. Anyhow, back to my questions:
Boneman has answered many of my questions regarding wiring. But I didn't want to continue bugging him and I hope some others might benefit from this thread since I know that alot of people have ordered/plan to order this kit.
1) How do you attach a wire to the positive terminal of the battery?
Boneman told me to use a ring terminal, but I'm having trouble getting a ring terminal to fit with the battery. The screw on the battery isn't long enough to grab if I put the ring terminals on the screw and then attempt to screw it down. They create too large of a gap for the screw to make contact with the bottom part of the positive battery terminal. I haven't been able to find a ring terminal that the screw can fit over the screw, but inside the little metal housing of the positive battery terminal. Am I just not looking hard enough for the right size ring terminal? I've attached a picture that I find in another thread of the battery. It shows pretty clearly the metal housing parts on the terminals that I'm referring to.
2) Can you attach the HID controller cables labeled "battery positive" somewhere other than directly to the battery? If so, where else is an option?
In the future, I might want to do some LED underglow lights. If I attach the ring terminal for the Halo eyes and the ring terminals of the 2 battery positive cables, I now have 3 terminals connected directly to the positive battery terminal. It seems like it would be a bit cluttered. Can/should I splice some of these together into 1 ring terminal and just attach 1 to the battery positive?
3) Are there any downsides to connecting multiple negative/ground wires to the same point on the frame? For example; Can I connect the HID controller ground wires to the same ground that the speedometer ground wire uses? Or is that mixing 2 different circuits and leading to a potential problem?
4) If someone has done the Bi-Xenon install (or anyone that has 2 controllers and 2 ballasts in their front fairing), could you please post some pictures of the setup. I'm having a bit of difficulty getting everything to fit nicely and out of the way enough that I'm still able to plug in all the necessary connections and turn the handlebars all the way from side to side without hitting anything. An image of a way to organize everything so it fits nicely would hopefully give me some ideas about how to arrange mine.
Also, any photo closeups of your batteries with mod wiring connected would be very helpful! Thanks so much for any insight you guys can provide. I wouldn't even be nearly as far as I am without this forum!
