wiring/cables with bar risers
expatmanxman
chesterfield (UK)
I want to put some higher and wider renthals on my FZ6N S2, a potential problem looks to be how little spare length there is on any of the cables, brake lines or wiring, it all looks just long enough with no slack. Has anybody put renthals on and if yes how did you get everything to reach, failing that I could put bar risers on but the problem would be the same although a little less severe.
I'm sure there are some pearls of wisdom out there.
agf
Go Naked- Its liberating
Melbourne Australia
you a right there is little slack the naked has cables and such threaded into the frame differently to the faired version to keep everything behind the headlight tidy you can re route all cables but it is a bit time consuming change too hel brake lines and ask them to make the fronts an inch or so longer but you need check the manual for cable routing fir clutch throttle cable and wiring from the switch clusters Sent from my iPhone using Forum Runner and it works every time !
