mimis
I heard that turning off my FZ6 S2 from the kill swich can cause problems to my engine and tha the best way is by turning it off from the key. What's the truth?
This has been discussed in another thread, but I can't recall where it is. I'm in the habit of turning off my bike with the kill switch for a couple of reasons.
One: By doing so, you are familiarizing yourself with the switch, so in case of an emergency, you can pretty much hit it with your eyes closed.
Two: If you are in the habit of using the key to turn off the bike, how will you know if the kill switch is working? Just like everthing else, like lights, horn, signals, you have to check and make sure it's working. Escpecially if it's an emergency.
I'm sure some other members will come up with a couple of good reasons why you shouldn't use the kill switch.
Damn... you beat me to it.I heard you were supposed to ride in 1st and just slam the brakes till the engine shuts off.
I second the battery drain and theft issue. I am a noob and have drained the battery twice! Now I only turn it off w/ the key for the only reason, I Won't forget it!!!the ONLY possible downfall of the kill switch is if you forget to turn the key off after. other than that there is no reason to not use the kill switch. If you forget the key in the on position you could drain your battery and leave yourself open to theft, but if you take your key with you then no issues :thumbup:
I'm in the habit of using my kill switch, putting the sidestand down and setting the bike down, then turning the key to off then to "lock". It's so natural to me now that it's all one swift motion. And since using the kill switch is part of everything, I don't have to worry about leaving it off and getting confused when the bike won't start.
