Yup, my right fork seal, the little black ring in the middle of my forks is spewing oil, slowly.
So what needs to be done and what does this mean?
time for a suspension upgrade!
I already have Race Tech springs installed. I guess I have to order replacement seals from them huh. I better go on their website and check it out.
*EDIT* Norbert beat me to it... LOL! OMG! WTF!!! Hahahaha!
Kenny, one thing you can try... If you can get your hands on a Seal Mate, some acetate or a strip of 35mm film, you can force it by the seal and down into the fork, then while pulling it back out, circle the fork with it so you are pulling it out all the way around the seal. Sometimes it can simply be a tiny piece of debris that gets wedged in between the tube and seal. After doing this, wipe the fork and area totally clean then bounce the front as hard as you can about 10 times and check for more leakage. If there's none, you've cleared the debris. If there is oil, then the seal is damaged and you need to rebuild. It's not a hard task though if you have the right tools.
Follow this video.
Seal Mate the Tool that Fixes Leaking Fork Seals - YouTube
Thanks everyone, look like I'm going to have a shop do it. But it's going to be a shop in Idaho. If it took John to do it in 2 hours, that equates about two days for me.
I can't remember when I had my front forks replaced with Racetech's but I think it was around 24k miles on the clock. I also replaced my oem oil with heavier fork oil. I currently have 76k. I had a shop do the replacements when I had my steering head bearings replaced.
