ebk02
Well, I would still stand as to engine issues as you have ruled out all "road" variables. I would possibly have checked out before selling, as it is really a great bike.
I know what your saying about having some tech check your bike to tell you they all do that.So I got home today and yanked the muffler off the bike. Man, loud as hell! But the vibration didn't change at all. After reinstalling the muffler and sitting on the bike on the center stand and revving it, you can feel the vibration in the pegs, the frame, the bars - Everywhere! I guess the next step is trailer it to the dealer and have them check it out. Thing is, I know the person who rides it will say its normal and I'll have fork over a 100. for that privilege.
As for all the other suggestions made, I've actually done almost all of them. I am going to try loosening the engine bolts, settling the engine and re-torquing the mounting bolts. And I think some of the riding posture suggestions need to be tried as well.
I have to thank everyone for the info!
I don't know if anyone has touched on an idea, but are the carbs synced? If out a bit, vibration would be more pronounced. And with the additional pressure on your right hand holding throttle, that may aggravate numbness.
I too have an 09, and find it relatively smooth. Having run the bike on the center stand eliminates tire, road, steering issues. It is the engine, and there may be the sync issue or other....
But anything over about 1/3 throttle the sync is out the window.
If we make some assumptions that it is the engine and nothing else, that helps. Example - rolling at 60mph and pulling in the clutch changes nothing while the engine is at 4000RPM, well that says that loading the drive train is not the issue. Speed is not the issue, so the final drive from the trans to the rear tire is OK.
This is when you pull spark plugs and look at colors, burn pattern etc. as its either the tune or the engines balance is wrong. Yamaha made a bazzilion of these so its not impossible that some went out the door with a fault.
Do the two bikes make equal power? Do they pull from a stand still at the same rate? Do they get equal or comparable MPG?
How is the clutch? Does it work well?
Can you do us a favor and pull the oil filter off, cut it open and pull out the pleated filter element? Cut the element so it can be laid out flat and look closely at the debris in the filter. It may tell us something.
I would also remove the air box and inspect the carburetor linkage. Use a flash light to confirm ALL throttle plates are opening the same amount at idle and ANY other position you can check. It could be the two carb banks need the linkage adjusted. I would guess the two shafts are synced by flow rate at the factory but you might try slipping a feeler gauge between the throttle plates and the body to see if they match. DO NOT FORCE ANYTHING as it can burr the throttle plates and make them stick. Let us know what you find.
- Up there I posted about rotating the levers. My hands were falling asleep until I got the kink out of my wrist so I had blood flow. It made a huge difference in how my hands felt.
My experience and perception of tingly hand is always the right hand and never my left hand. I attribute that to holding the throttle in a specific position and not from vibration. I would say when I'm conscious of my grip and relax it a little the tingly hand goes away. I think it has to do with blood flow more than anything else. Like when you sit on your leg funny and your foot or leg fall asleep. That's blood flow. It's your body's way of telling you circulation has been interrupted. I believe that's why those "Cramp Buster" levers are so successful. If you are only experiencing it in your right hand it's probably not just your riding position. Try to change how you grip.
