- Joined
- May 8, 2008
- Messages
- 15,007
- Reaction score
- 1,177
- Points
- 113
- Location
- San Diego, Ca.
As many of you know I’m pretty interested in the electrical as well as other aspects of motorcycling. I try to give input on a regular basis with the many contributing members of our forum. This is a great forum and I’ve learned so much from all of you that contribute riding and technical experience as well as the great social platforms that have created lasting friendships from all over the world!
This past year has been less in the area of employment for me but I do not quit looking for opportunity and hope that I have found an area for some income as well as contributing to this forum and the motorcycle community with a product, I believe will be beneficial in many ways.
This relay assembly will work with any H7/H4 configuration that doesn’t use the low beam function in the dual headlamp FZ6 or any make motorcycle of the same configuration headlamps. This will also provide the proper switching for converting to the naked version single headlamp from the dual headlamp because the dual headlamp faired FZ6 doesn’t provide low beam switching.
I’m including for review, a description and instruction set (PDF format) for those that might be interested in this modification.
I’ve tried to be complete in the instructions and if you print out the sheets so that you can
cross reference the instruction to pictorials it should be easy to understand.
Special thanks to all on the forum that contribute and continue to contribute mods to make these bikes even more special.
Also a big thank you to smokenu (Dave) for letting me do this mod on his bike. We had a fun time doing this over a month ago and it went great without a hitch from the very beginning.
Galen on our forum has also used this unit on a single headlamp conversion and now has proper High/Low beam function.
Edit: I've recently found out the the FZ16 single headlamps come with a dual filament 35 watt halogen lamp (Low Brightness). You can switch to the 55 watt Halogen commonly used in the US and other countries by incorporating this relay kit.
