jako2005
This is my first time to post to any discussion forum, so please excuse any displays of poor form I may perform.
I have a 2005 Yamaha fz6 fazer, and I'm having some electrical trouble that I can't figure my way out of alone. After rewiring the bike three times, and effectively chopping up the harness a right bit excessive, I finally had the thing starting about a month ago, and even got to ride it four or five miles down the road before it shut off and refused to start back up. The only way I could make it operate, even in that limited fashion, was by grounding the signal wire from the ECU to the fuel pump relay, and then installing a second relay switching the red with blue tracer wire up stream of the pump and injectors, and after the cutout relay module. I've studied the diagram extensively, but my limited understanding of the way In which a diode matrix functions, and my lack of full confidence in the entirety of the forty some odd splices I had to make on the harness has me freezing up and unsure of the methods I'm using to troubleshoot the issues on the bike. Anyway, the bike would run but having the pump constantly on caused engine flooding, smoke out the tail pipe, and the aforementioned inability to stay running or fire back up after a short period of functioning.
Fast forward to this last week, I bought a fleebay used wire harness and three that son-bish on there just to be met with the same problems I ran into before chopping up the last harness.
I haven't got pump prime. The blue with white tracer wire at the starter solenoid has battery plus, for some reason, and I cannot get this damn ECU to voluntarily ground that little omron relay in the black death trap box. I don't want to cut into this harness, but how often does an ECU, realistically, experience catastrophic failure? Also, if anyone could explain how the diode matrix works within the confines of the starter circuit cutoff relay, that would be very much appreciated.
Thanks for reading,
Jake
Thanks for reading,
Jake
