LVNeptune
I think I may have put too much oil in my FZ6 when I dumped it and replaced it. I let it empty out completely from the crankcase and oil filter line and filled it back up with 3 quarts. I think it might be slightly under 3 qts but I have been unable to find a 100% "level" surface to actually test the dip stick. If it is over is there any easier way to drain the excess oil without using the drain plug? Maybe siphon it from the filler? Just asking, last time oil went everywhere >_<
Also, what are the symptoms of too much oil? What damage can too much oil do? I smell burning coming from the center of the bike but not sure specifically what it is, definately isn't anything caked on it. Too much oil = less being pumped = hotter = burning smell ? The temperature gauge didn't go above half so it's not overheating, afaik.
Thanks!
Thanks!
