Tight Clutch
Replacing the throttle cables is simple, but very frustrating. You should remove the airbox, battery, and battery tray and you will be able to see the routing of the cables. It is a very tight squeeze and will require a good flashlight and a lot of patience to get into place. I found that removing and remounting the cables to the throttle body was easy compared to getting the cables through the frame and routed correctly to the TB.
