ItsAllGood
Pro Aris et Focis
- Joined
- Dec 22, 2008
- Messages
- 18
- Reaction score
- 3
- Points
- 3
- Location
- Peoples Republic of California
During the simple task of putting on frame sliders I stripped out the threads in the left side engine mount. You know, hearing that gut wrenching POP that happens right after your mind is telling you "This just doesn't feel right" as you're pulling on that torque wrench.
Post action observations:
1) Lucky me(?) The mount is a "Hole-Through" type, meaning it doesn't end buried in the case somewhere.
2) The threaded area intended for securing the bolt threads in the engine case are only half stripped because for some odd reason thats only as far as the bolt penetrates (factory as well).
3) 40mm original thread surface / 23mm thread surface remains after strip.
4) Factory bolt length = 50mm.
5) Original slider bolt length = 80mm
6) Total length required for securing w/o slider = 70mm +/-
7) Total length required for securing w/slider = 100mm +/-
So anyway as I see it, I'm looking at four options.........
1) Forget the sliders and replace the factory bolt with a 70mm bolt.
2) Forget the sliders and replace the factory bolt with a 80mm bolt & nut.
3) Use the sliders and replace original slider bolt with a 100mm bolt.
4) Use the sliders and replace original slider bolt with a 110mm bolt & nut.
To tell you the truth, after seeing the fragility of that mounting point I'm also rethinking the use of sliders and going with case guards.
Don't want to open up the whole Pros vs. Cons of Sliders debate.....just wondering if somebody sees something I might have overlooked for a repair option.
Thanks......
Thanks......
