Any progress on this?
I'm wondering if the throttle plate shaft of throttle plate may have shifted laterally and is catching? The TPS could also have a mechanical problem causing interference.
Like you mentioned earlier, I'm guessing either something fell in (or ate its way in) or someone has done something to the actual butterflies which prevents them from seating in the TB.
i.e. the throttle plates (brass plates), do NOT align as easily as most think. That is; if removed, few take the time needed to properly align them and they stick and do NOT close all of the way. Which could be the problem here.
Removing the air box lid and looking in the stacks would verify the "intruder" symptom and maybe even the tampering symptom.
