Speedo Healer and 15t install
OZXJR
Super Moderator
Adelaide,South Australia
Well yesterday I installed my S/H and 15t front sprocket.WOW what a difference.
Like others have said"Best bang for buck mod there is "
A few pics of the install.
First,the unit itself.I was surprised at how small it is.
picture.php
Once you raise the tank the plugs you need to find are on the clutch side under a rubber boot.The 3 pole one on the right in this pic.
picture.php
Pull the plug apart and plug in the S/H harness like this.
picture.php
Route the cables to the underseat storage and mount with the double sided tape provided.
picture.php
Plug in the top speed recall button and mount where you want(I have not mounted it yet.
Then program as per instructions that came with the S/H.Takes all of 30 secs.
Then onto the sprocket.First loosen the rear wheel and push it forward.
Remove the 3 bolts holding the cover on,I left the gear lever rod in place without any probs.
Its a good idea to clean the cover at this point.
picture.php
Then push back the tabs on the washer ,select first gear and get someone to stand on the rear brake(7yo up and coming footballers are good at this ;) )
and remove the nut holding the sprocket on.
picture.php
Slide the sprocket off with the chain still attached then remove the sprocket.
Put the chain on the new sprocket and slide back on the shaft.Replace nut and tighten ,same as before,get someone to stand on the rear brake.
Bend back the washer tabs and replace cover.
Adjust chain slack and tighten rear wheel and your good to go.
Go for a test ride and enjoy the new mod :D
1.5 hours and all done,all in all very happy with it ,should have done it years ago.
One word of warning,watch out for pinching your hand and ending up like this :rolleyes:
picture.php
Stumbles06
Nice work Mick. Blood Blister and all... I'm Impressed... :spank:
Umm, 1 question... When was the last time you took the sprocket cover off and cleaned... That's a whole lotta gunk under there...lol.
:rockon:
CHEMIKER
Running Moderator
San Jose, California (GMT -8)
Thanks for the writeup and pics Mick! Did the 15T install but haven't done the speedohealer yet. Good to hear that it's so simple. Think I'll order one today.
motopete
Sooke BC
Good work, I thought this is a awsome mod too, until I put a +2 on the rear. Give it a try, now that you have a S/H. Now the bike moves. They should have done this at the factory, but then I guess we wouldn't have as much fun modding, right.
stryken
Vertically Challenged
Imperial, Missouri
Good work!! Wow the speedo healer is small, guess I will get to ordering one as well then I can stop doing all that guess work while riding down the road.
Australia
:rockon:
And you wonder why i give you crap about your chain & sprockets......LOL!
Man get that bike down to the new shop...and let me clean it....free of charge...i think i have enough degreaser & truckwash!
That's a serious offer....plea!
:D
OZXJR
Super Moderator
LMAO,I actually put that pic in just for you.I new after the rear sprocket comment you would say something.
Thanks for the offer on the clean,might take you up on that.I want to see the shop anyways :D
Australia
I just wanna show off the before and after shots.....i know there is a shiny bike under all that!
:thumbup:
FZ6drummer
Longwood, FL
this post has inspired me to finally do this mod. i've read so much about it, and now i think i'm ready to go for it!
thanks for the pics and install info. hope you enjoy the new mod :D
OZXJR
Super Moderator
So where did you mount the TSM button? ;)
It's under the seat at the moment mate,haven't found a spot I like yet.
EDIT:Found one thing about the mod on the way to work this morning,if you have a gear indicator make sure you reprogram it BEFORE you go for a ride :banghead:
Mexi-can't
Biker dude
Colorado
I had mine mounted at the front of the frame where the wires come through on the right side. It's such a small switch it's easy to hide. :thumbup:
dantow
The Phoenix
sydney
Hey mate, have you checked your speedo of against a gps? I went of the calculations the gearing calcs they give you first and it was still a little out.
OZXJR
Super Moderator
Quick update,checked my speedo healer settings against my GPS today,-11.1% seems to be as near as dammit to spot on,all good :thumbup:
