andyfazer600
My side stand cut out switch has been inoperative since I got my FZ6 last July. Assuming it has been overridden and is not broken how would I reinstate it? i.e. undo the override
The 2 wires that go to the side stand switch are blue with a green tracer and a black.
I don't know the the state of the switch when the stand is up or down. In others words, if the stand is down is the switch a normally closed (NC) or is it normally open (NO). There may be a jumper wire place across the wires going to the switch or the wires/plug have been removed to create an open circuit.
Inspect the wires at the switch to see if you can establish that the modification has been done at that location. If the mod has been done elsewhere we'll talk about what and where we might find it bypassed.
I guess the switch works by shortening the wires and shutting down the engine. Makes more sense for me - imagine losing connection while on a highway ride and stopping the engine at 130kph
I thought I had fixed this however on my first ride out since crimping the cables back together the engine was cutting out when a gear was selected no matter if the side stand was up or down. To get around the problem I reverted it back to the short circuit 'over-ride' as per before. My question is would it matter which way I re-connect the two cables? e.g. a positive and negative which will only work correctly when connected + to + and - to -
Otherwise I think the switch must be defunct
Now you've established that the switch or whatever mechanically operates the switch is bad. http://www.600riders.com/forum/showpost.php?p=574293&postcount=2
Now inspect the switch at the side stand to make sure it is there and it is activated by the side stand. If it is there and mechanically operated by the side stand or it does not exist order a new one.
Edit: If it is not there you will probably also need the the machine screws and nuts that hold it on the bike...
I've previously removed the switch for another reason so it is definitely fitted and the plunger on it that is operated by the actual stand itself seems to work correctly. I'll have a further look inside it for possible damage
As I recall, there was a small spring in there (likely to push contacts together). Did you have a very small spring in there?
