KB2WYL
CQ CQ, DE KB2WYL
Hi all. I'm finally getting serious (and the time) about giving my '07 some attention. I joined here a couple years ago when I got her, but never posted much and only did a few simple mods. I find myself coming back here again and again, so I figured it's time to start posting some of my questions. As well as offering some of my knowledge as well, can't just keep searching
So one of the things I'm doing right now (the bike is partially torn down while I clean and mod) is the S1 header mod. Picked up a set for 15$ + 20$ shipping. Shoot, can't beat that. Currently I'm running the PCFC fuel controller with the secondary cat delete, and the exhaust cut open, baffling removed, welded back shut mod. After that, I also enlarged the two outputs and added about 4" of 2" pipe to each. It sounds great, runs great, but of course I still have the 02 sensor hooked up.
So, when I put on the S1 headers, my plan is to weld a bung on and keep things the same, only difference being the two small primary cats will be gone. Finalimpact, I know (at least you) have done this. Should I place it exactly the same spot? Are there any advantages to going a little closer to the heads, or tail? The bike has just over 20k, so not sure how much of a difference not having the cats will make. At this point I have the controller dialed in pretty well, and usually just leave it in the stock map mode, with slight additions on the fuel at low, mid, and slightly more still at high, RPM.
Thanks very much, really. I'm taking some pics and I'll start to post some of them up. Should I just start a new thread, "20K finally rebuilding" or similar?
Loren C.
KB2WYL
2007 FZ6 (do I type in all the mods, for my avatar, in the "what bike do you have" field in settings? I couldn't find a place to add a signature.....
Loren C.
KB2WYL
