jstoof
I believe my rear brake needs to be tightened but not sure how to do it...
So this should tighten the rear brake because as of right now it barely aids in stopping i can slam on the rear brake and it wont skid and will barely help stop
Yes i understand the physics and what not of it but i just think the rear brake still needs to be tightened some because if im applying just the rear brake you would think that it should at least stop the bike rather then just letting it coast... and i dont think the pads would be bad it only has about 2300 miles on it but i could be wrongYou should be able to skid the rear tire by stomping on the pedal. If the pedal is too far 'down', you can't get enough force on it to do so. If the pads are shot, there's a lot more wrong than just the pedal height.
Get thee unto a formal training course........ the weight transfer ('dive') that occurs on a motorcycle, particularly one that has a short wheel base will almost completely 'unload' the back wheel. You can't use it to stop, if the wheel isn't touching the pavement.
The question I think you are asking, indicates there's a lot of room for learning....:thumbup:
Back brakes on a street bike are almost in the 'Hail Mary' class, for stopping the bike. Less than 20% of all the stopping power available comes from that wheel.
The vast majority comes from the front. That's why the rotors are so much bigger, and the calipers more advanced in design. When the front 'dives', that puts a LOT more weight on the front tire, which gives you a LOT more traction.
Haha in know the front brakes are good my first day riding it i learned what a stoppie was lol but ya ill go check the brakes and see if there is something else going on because i definitely cant get it to skid with just using the rear brake
It doesnt... when i was looking for an fz6 i test drove a different one and the rear brake was much better on that one so i know its something with mine and just not in my head i just cant figure out what it isWhat happens when you rapidly 'pump' the rear brake? Does the pedal become more firm?
the pedal travels fine but just doesnt grab really until the very end which by then doesnt offer much braking resistanceSo the pedal 1) travels through a 'normal' arc, and doesn't slow the wheel, or 2) it moves too easily through the arc and never gets any resistance?
