Still waiting on an opportunity to buy a new battery (I'm not even married, how do parents find the time for anything?).
I tried to run a test of the stator coil but don't know if I did it right, but it seems to check out.
I unplugged the RR and set my pocket tester to "200", which I think means "0-200 ohm range." It's the lowest setting my tester appears to have (could be mistaken). I shorted the tester and got a reading of 00.3, which I interpret as .3 ohms. Every which way I put the tester into the white wires at the RR plug, it read 00.6, or (I guess?) 0.6 ohms. If I left the tester probes in the socket long enough, it would drop to about 0.5 ohms...don't know why. Anyway 0.6 minus 0.3 is (drum roll please) 0.3 ohms, which is right inside the functioning range for the stator coil (0.22 - 0.34 ohms).
It's only 10 am local time and there are lots of houses / apartments nearby so I'm going to wait until lunch to fire 'er up and check the input voltage to the RR. At rest, I read 12.8ish volts on the red / black lines at the RR plug which I am guessing is battery voltage (?).
Also can someone explain this cryptic instruction in the service manual?
Service Manual said:
a. Set the engine tachometer to the ignition coil of cylinder #1.
I know what the ignition coil is (or at least I think I do), but what relation does that have to any tachometer?
Update 1: Just checked input voltage by hooking tester up to white wire leads. @ 5k rpm I read about 70. Tester set to AC Voltage, "200" setting (again, assuming this is 200 volts).
Update 2: RR was
not hooked up when I did that test.
Update 3: Checked RR diodes, all were good. .54ish on all tests that were supposed to be non-zero, and nada on all the other connections. So now I think the battery is dead?
