Pod lights
you did bd43 too?
you have two pod lights while Ignition is on, Two headlights and pod lights when you turn on engine and high beam with all lights when high beam?
Yes I did bd43. I wired the pod lights into the turn signals so they also operate as turn signals. And [MENTION=15974]FinalImpact[/MENTION] is correct, I also did the dual headlight mod, so if the engine were running both pod lights AND both headlights would be illuminated. Both headlights are on even on low beam due to the dual headlight mod. So all lights (pod and headlights) are ALWAYS lit.
