fazer.rider
i usually change oil with rotella t syn every 3500 miles with new filter. seems like a waste so i just did a change but kept the old filter. everything should be fine i assume? thanks.
btw my givi engine guard blocks the drain nut but it's not that bad, i just loosened some bolts and pulled out the guard an inch out so i can wrench the drain nut. can't use a torque wrench but hand torque should be fine.
