Mikeinho
Hi - hope someone can help.
Bike turns over fine, but does not fire-up after dry storing during the winter. The only sign of anything different is no usual whine from fuel pump when switching ignition to 'on' position. Checked all the fuses (they are all OK), and there are no fault codes on the dials. Kill switch is in correct position... I've made that mistake before!
I can still hear the fuel pump relay switching when I key ignition to 'on', but have no way of testing if broken. In fact, I can't even seem to disconnect the relay, and don't want to force it in case I break it. Without knowing for sure, I'm guess it is the fuel pump itself, and will need replaced. Last time I had it running, the fuel pump did sound a bit weak.
I've found plenty of OEM replacement fuel pumps for sale (less than £30 new & delivered), but I'm interested in buying a genuine part. Does anyone know the part manufacturer & part number?
Also, any tips / links to pics when replacing the fuel pump would be much appreciated.
