Okay, is that something that can be transferred from the old pump to the new? I was under the impression it all was included… the kit does already have a regulator installed
I wasn't sure if you were getting a kit, or just the pump motor.
Looks like the kit includes the regulator, and also the tank seal, which is good because the factory seal is quite expensive.
I finally have injectors and fuel pump coming Monday… cleaned the fuel rail and lines so hopefully after installing everything it fires up and idles without an issue! Next it’ll be onto handlebars, exhaust replacement for damaged welds, rear set, suspension, chain and a second oil change and coolant flush. Pray for this 80,000 mile bike haha
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
