So, my planned de-winterization didn't happen this past weekend, as I ran out of time, so my MiG is now sitting in a half-assembled state at my dad's garage. I am hoping to hear some opinions from people here on the following few points:
1) Racetech springs - i've decided to replace the OEMs with racetech, but the springs that came in are shorter than the OEMs. I'm assuming that's ok, given that racetech also included a long aluminum tube that seems to be meant for a spacer. One thing about it though - it is smaller in diameter than the OEM spacer (its external diameter is exactly the internal diameter of the OEM) - so i'm thinking about leaving both spacers, with the OEM spacer ensuring the racetech one is centered. Any potential problems you can think of?
2) Front axle bearings - when should I replace the bearing on the axle? The front bearings take some effort to rotate - nothing crazy, I can still do it with my finger, even when covered with grease, but it's just not as light as the rear bearing. Otherwise everything looks ok -fairly clean original grease inside, no play or anything. Not sure if it makes sense to replace them, since i now have a the wheel off and have a couple of days to order the replacements if needed.
3) Rear shock mount spacer - I'm at 13k, and figured, since I am taking the bike apart, i may as well look at/re-grease the swingarm bearings (16k service). According to the manual, once the bolt of the rear shock's lower mount is out, you should be able to just pull out the spacer. Yeah, that didn't happen. tried anything from light tapping on it to wise grips (obviously withing limits) - it doesn't move at all. Any thoughts/experiences?
4) Galfer rear brake line - ordered from pashnit, looks correct length/turn, but still - to put it into place, I had to twist one of the ends quite a bit - I was able to install it, but there is some twist tension on the line - want to make sure that's not going to cause any issues.
