This project is taking a while, but mostly because I'm taking my time, and not rushing anything, and working on it a little bit after work each evening.
Anyway, last night I finished mounting the projectors, and resealed the headlights.
...only to discover that one of the mount points on the projector had come loose from a bracket, and that the cutoff for the lowbeam wasn't horizontal.
So, back to the oven. I unsealed the headlights again, fixed the wonky mountpoint, and rebent the lower bracket to align the cutoff properly.
Then, into the oven a third time to reseal everything again, right before I called it a night.
I also discovered one of the housing mounting tabs had cracked, so I JB Welded it before turning in.
This evening, it's all cured, the mounts are solid, and the lowbeam cutoff is horizontal. So, I give you the completed R6-projectors-in-an-FZ6-headlight-assembly project!
Here you can clearly see the mounting brackets I had to make. They won't be so visible once the assembly's mounted on the bike and the headlights are operational.
You'll notice that I also decided against installing the CCFL angel eyes I had planned. I just wasn't happy with the way they were sitting, and I just wasn't happy with the silicone sealant I was planning to use. Plus, I couldn't come up with a satisfactory way to route the wiring that wouldn't look like crap and be insecure.
Now, I just need to swap out this assembly with my stock assembly, and then install the HID lowbeam.
I'll take before and after shots of the headlights at night. The after will include the projectors with normal bulbs, and the projectors with the HID installed.
