Lumpy idle when cold started
Dresnewtoy
southern maryland
I'm the second owner of my '08. The only modifications i know of is that the previous owner drilled out the stock exhaust.
When i cold start the bike the idle is lumpy for a minute or two then it smoothes out. The bike runs great otherwise. Is this normal?
I tried to reset the ECU by disconnecting the battery leads and shorting them for a few minutes.
Any ideas on what's going?
arsity
Michigan
I recently installed LeoVince slip-ons I can hear the same "wobble" sound when I cold start the bike. Mine too smoothes out after a minute, so I dont worry much about it though...
When the engine is cold, the ECU has it run richer (like an automatic choke). Slightly rougher running (the mixture is richer) and a higher idle is normal.
If you to post a video would help but I think your fine..:thumbup:
FIZZER6
The Angry Blue Mantis
Virginia
My 2006 has pretty much done this since day 1. It smooths out as soon as it's warm and does not do it again until I restart. Never worried about it, bike runs great. :thumbup:
dpaul007
Lake Crystal, MN
My bike also did this when I bought it. PO said it started when he installed the LV pipes. After a bit of researching and adjusted the CO settings and did a throttle body sync, and it has smoothed it out considerably.
