Good point, I forgot about contaminants getting inside the pressure sensor. Even a tiny spec of dust or moisture will kill one. Those things are too sensitive for this application. Jeez, I must've been really tired when I posted that. Fridays, I swear! lol
Can't wait to see this thing finished. :thumbup:
FWIW; pressure transducers are used in plenty of harsh and dirty environments. The FZ's intake has one. They can handle it. If need be in line filters can be used but seldom is that required as there is no flow to create deposits. Just a dead end street so to speak of.
Flow meters and/or flow sensors on the other hand are very sensitive to contamination especially when the rates are low, i.e. below 1 ccm. Tiny particles can easily skew the calibration substantially! I guess it really depends on the type of sensor used. Hot wires and bridges are the most common and they are very fragile w/regards to contamination.
As you were.. .. .. but yes, the addition of a vacuum sensor with an A to D converter for the G force/position sensor would make this very robust if designed properly.
So the question is, can it all be done at a hardware level?
