saminator
How many miles on the bike?
10,000. I bought it from a woman at 7,000.
I would be surprised if the clutch needs replacement at 10k miles. Mine has 13k and it still like new.
I will try gunning it in a safe place. I have yet to feel any slippage yet. It also just seems weird how far out I have to let the clutch before it bites. I had an SV650 before and I would let out the clutch like 3/4in at it would grab.
If you're really paranoid, you could take the clutch out and measure the friction plates and springs. There's minimum specs in the service manual
the clutch cable doesn't run by the seat?
Lubing the cable with 30wt motor oil as suggested in the manual will lead to black slurry from the cables exit.
Different manufactuers have their clutch engagement zones in different area's of the lever travel.
Finalimpact (Randy), yes the overflow tank is ahead of the engine and yes, the overflow hose for the coolant tank is indeed right above the header and could dump anti freeze on the header if it overflows...
Any updates???
+1 on the above.
Make sure you soak the friction plates in oil for several hours...
Also, pay attention to the marks on the inner hub, they must match up with the outer clutch "Boss".
Obviously, the friction/steel plate order must be replaced exactly as they came out....
