SweaterDude
Broke-zillionaire
- Joined
- Apr 20, 2011
- Messages
- 1,051
- Reaction score
- 8
- Points
- 0
- Location
- Nashville, TN ([email protected])
So I have been riding it pretty frequently and the smell is still their each time with varying intensity. I opened the oil fill hole on the clutch cover after a ride and noticed no unusual odor. It seems like the smell is coming from the exhaust pipe where it heads straight up and then goes up to the tail. I am trying to figure out if maybe some insulation has failed or something I put in the storage slipped down onto something very hot. I no longer think it is the clutch because it has yet to slip on me. The adjustment of the clutch cable is still concerning as it seems like I shouldn't have had to adjust it out as far a I did.
did you put new springs in? if you put aftermarket/race/sportier clutch springs that can change things a bit, heck even new stock springs can make a decent difference depending on how many miles/wear the old clutch went through.
also, like i said in my above post, i dont know if its a basket type clutch, but if it is, then you need to make sure all of the parts went back in ALL THE WAY. if the puller plate isn't coming the full way back it can DESTROY your clutch quick. on most dirt bikes there is a "catch" before the puller plate goes in fully. ive seen a few cases where people have rushed a rebuild and neglected to tweak the plate past the catch. the clutch will work like this for a while but when the clutch is pulled at a high RPM the centripetal force on the friction plates and spacers pulls them out and they can get stuck on the outer rim of the basket. the puller plate then returns at an angle causeing uneven pressure and eventually (not that long really) broken plates, which then float around in the housing causing even more damage.
not trying to worry you but oil is cheaper than a new clutch.
