Fitting different calipers ?
AdamFZ
West Sussex, UK
Do you know if its possible to fit different calipers ? because look whats happened to my freshly re-sealed caliper ! :(
Do you know if the other Fazer, earlier and later model calipers fit straight on ?
One side of that was broke for a while - lucky you it didn't rotate into the wheel and take you out!
S2 Forks + S2 calipers...
Sorry to see this, unfortunately the front calipers are not directly interchangeable, the 2007 model onwards have more pistons, and the design (mounting points) are also different :(.
Good luck.
And make sure you get the CORRECT SIDE caliper. The bleeder screw will be in different locations between the rt and left sides.
2004-06, S1 caliper will fit...
Some countries make the "year bike", the year it was sold in...
Just make sure you get a TWO PISTON, correct side caliper.
