Fitting different calipers ?
AdamFZ
West Sussex, UK
Do you know if its possible to fit different calipers ? because look whats happened to my freshly re-sealed caliper ! :(
Do you know if the other Fazer, earlier and later model calipers fit straight on ?
One side of that was broke for a while - lucky you it didn't rotate into the wheel and take you out!
S2 Forks + S2 calipers...
Cloggy
Euro Mod
Alkmaar Netherlands
Sorry to see this, unfortunately the front calipers are not directly interchangeable, the 2007 model onwards have more pistons, and the design (mounting points) are also different :(.
Good luck.
And make sure you get the CORRECT SIDE caliper. The bleeder screw will be in different locations between the rt and left sides.
2004-06, S1 caliper will fit...
Some countries make the "year bike", the year it was sold in...
Just make sure you get a TWO PISTON, correct side caliper.
