ed c
The short story: bike won't start and is displaying Er 1 which from an earlier post I understand means:
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
The long story:
Rode for about 30 min this morning while running an errand with no issues. Post ride, installed a Throttlemeister and after adjusting, ran engine to test operation of Throttlemeister with no issues at all. A couple hours later, while showing my father the motorcycle and starting it up once with no issues (ran for maybe 5 min), attempted to start again but engine would not turn over. Turning the key to 'on' resulted in power to the console, all guages seemed to work fine and I heard the whining of what I believed to be the electrical system starting up (same sound I hear every time I turn the key). Turned on the kill switch just like normal and pressed the ignition switch. Rather than the engine quickly turning over, as usual, it produced a loud buzzing sound and the power cycled off and on (console powered down and immediately powered up again as if I had just turned the key back on). The console displayed Er 1 (described above).
I have not been able to find much in the owner's or service manual regarding explanations for the malfunction or how to fix. How accessible is the ECU? I'm wondering if this is something I can attempt on my own or if I should contact a dealer.
Any assistance or recomendations are greatly appreciated.
ed c
Fault code: Er-1
Diagnostic Code: --
Malfunction in ECU.
The long story:
ed c
