nemoest
So I was out and about on my bike getting some more practice in, when I noticed it died while I was waiting to make a left. Odd, but I was able to start it right back up, so I decided to head back home.
When I pulled into my parking spot, I decided to let it idle a bit to see if it would do it again. Instead, the check engine light came on and it threw fault code 46 (which I did look up, although I don't completely understand). I flipped the cut off switch and noticed the fan was on, and the temperature indicator was all the way at High.
Now, this made me think back to when I started it earlier. When I was starting it a few hours ago, it threw Err-Code 1 (as if the side stand was down, which it wasn't) and then the gauge cluster just faded away. I thought maybe the battery was dead and it didn't have enough power to start it up, but I was able to get it started after turning everything off, and then back on again.
I'm probably going to take it to Yamaha, but I was wondering if anybody had any ideas on what to check?
The coolant is in between min and max, the oil was recently changed and at a good level... if it's electrical I'm probably at a loss anyway.
Thanks
Edward
2004 FZ6
Thanks
Edward
2004 FZ6
