I would NOT recommend it as the cylinder head is aluminum and the plugs are steel.
When the manufacturer gives a torque value for a fastener with dry threads they are taking in to account the amount of friction between the 2 parts. When you apply anti-seize you are lowering the amount of this friction from the equation. What this means is it is easier to turn the fastener (spark plug) and you will apply a higher clamping force (axial load) before you hit the stated torque value. It is very easy to pull the threads out of the cylinder head well before you get the plug tight.
________________________________________________________________
Something I found posted below which may help. I know from experiance of
steel spark plugs trying to seize in the
aluminum head of my KLR and some other engines. It would take several turns back and forth to release a spark plug and NOT strip the hole... The KLR I referrred to (1989)went thru several plug changes in its 73,000 miles with just myself... Every machine I change a spark plug out on gets anti-seize
(not alot).... Haven't stripped a spark plug hole out in 36 years...
I agree thou, torquing the plug down
should be less.... I'd prefer not to have to deal with removing a head for a spark plug heli coil should the different metals corrode together which is not uncommon...
CHANGING SPARK PLUGS
When changing spark plugs, wait until the engine has cooled to remove the plugs. This is very important with aluminum cylinder heads because it reduces the risk of damaging the threads in the cylinder heads when the plugs come out (aluminum is a much softer metal than cast iron).
Most threads on spark plugs for engines with aluminum heads are either precoated to reduce the risk of thread damage, or the plug shell is made of a nickel alloy
. If the plug shell is black or plain steel, however, you should put some antiseize to the threads, and reduce the applied torque by about 30 to 40%
Do not use antiseize if the plug shell is nickel or has been precoated. Antiseize acts like a lubricant and may allow too much torque to be applied to the plugs, damaging the treads in the cylinder head.
