dturpen
Gamer/Bike Enthusiast
One of my headlights went out recently (turned out to be a kink in the wire rather than the bulb :spank, so I decided to get some new brighter headlights, since I do a lot of night riding. I work 3pm-12am, so I actually do MOST of my riding at night.
Anyway, I bought the DDM tuning kit since it was about the same price as a new set of brighter bulbs, and they carry a really good warranty. I was a little worried about the quality of the kit, but when they came in, I was very impressed. The headlights shipped very quickly, and the ballasts and bulbs are packaged well, and seem like they are of very good quality.
I should've taken some pictures of the kit before the install, but I was so excited to get everything put in, that I didn't take the time to do it. I thought that it might be difficult to wire everything together, but it turned out to be very easy.
There are only a few connections. You connect the ballasts to the bulbs with three connections, and then there are two wires that have male spade connectors on the end: a positive wire, and a negative/ground wire. It's literally as easy as connecting the ballasts to the bulbs and then plugging the positive and negative male spade connectors into the factory headlight connector. Make sure that you connect the wires to the correct side of the factory harness. In my case the factory harness negative wire was black on both sides, and the positive wire was yellow on one side and white on the other.
It will be a bit different for a stock FZ6, since the stock FZ6 has one H7 and one H4, but it should still be fairly easy.
I just hid the ballasts and connections back behind my Buell windscreen after testing to make sure everything worked, and voila! I now have much brighter headlights.
I don't see any scattering of the beam in my experience, and it seems to have a pretty sharp cutoff. I still have some room for adjustment to aim the beams down if needed, but I haven't had anyone flash me yet, so I don't think they're blinding oncoming drivers. Even if they are, I can still aim them down a bit.
I'll take more pictures of the beams themselves after it gets darker, but here's a few pics that I already took. Excuse the quality, they are from my cell phone.
