bryanwny
Thanks to whoever originally posted a thread some place on here about pinching the beads together with zip/cable ties. :thumbup: Bigger props to whoever came up with the idea!
I've never changed a tire on anything in my life; don't even own any tire irons/spoons or rim protectors. After watching some videos and doing a bit of reading, I decided to give it a go since it was Sunday and nothing was open. Had to work Saturday, Monday is a holiday, and I picked something up in my rear tire a few days ago. I was getting close to needing new tires on both the front+back and already had a new set of PR2's on hand.
I screwed (4) pcs of 2x4 together to form a box to keep the rim/rotors up off the ground. Used a long section of 2x4 to act as a lever along with a shorter piece to pop the beads (after I removed the valve cores to get all the air out). Wrestled with trying to get the back tire off the rim. Swore more than a few times. Said "I'm smarter than this stupid tire!" and cut all the way around the sidewall on both sides with a utility knife (which is actually pretty easy after you scribe it a few times in the same spot to sink the blade all the way in) and watched the tire fall right off; leaving just the sidewalls to easily stretch over the rim. lol. Someone will get a laugh out of those when I drop them off to get disposed of I'm sure! :Flip:
I put (8) 24" long zip ties loosely around the new tire. Put it on the ground, knelt on it, snugged all the zip ties up until the beads were touching. Cleaned the insides of the rim. Sprayed a bit of windex on the beads+rim. Knees + hands + weight + bit of muscle == SUCCESS! Both the front and back tires went on the rim in MAYBE one minute, without using any tools to pry on it. Pulled the zip ties off to re-use on the front. Set the beads, sprayed a bit of windex around and checked for bubbles. Found 2 tiny spots on the rear about an inch or two from each other that were leaking a tiny bit. Bounced the tire on the ground a bit and tried again; fixed. Put the core back in and inflated to proper PSI. Repeat for front. Cleaned the rims up and installed them back on the bike.
I will probably never pay anyone to change my motorcycle tires again! I love the internet :rockon: Pics attached. The yellow bungees were just on there because I was going to take it some place to have the tire mounted and I was trying to keep sprocket/spacers in place.
