Spurioushamster
Hi everyone, after lurking in the background for the past few weeks I thought I'd introduce myself and get some advice on a job I'm planning. Sorry if this has been covered before, I searched for it but couldn't find any info.
I got my 05 FZ6N the other day, and it's in remarkably good nick, except for a bit of corrosion and flaking on the sub-frame and engine. My plan is to remove the engine and sub-frame, shot-blast them to remove the flaking silver paint (I have access to an industrial shot-blast cabinet) and then paint the engine, sub-frame and main frame using VHT satin finish black spray paint.
What I wanted to know was, can I put a fully assembled motor into a shot blast cabinet, if I'm super careful about masking off? There are some rubber gaskets I was going to cover with stainless foil, and I was going to machine up some blanks for covering the header connections. Can paint stripper like nitro mors be used to remove this engine paint?
I also wanted to know if anyone has any tips for painting directly onto aluminium with VHT paint, whether I need to use a special chemical primer or not, and if anyone has tried clear coating a satin effect paint job?
Any constructive advice would be very welcome,
toodle pip from England-shire
